Mastersbilt Help
  • settler98
    • Oct 2012
    • 86
    Mastersbilt Help
    I am struggling to get a grip on this car so any useful, experienced suggestion is appreciated. We are new to Mastersbilt but have run dirt late models for 20+ years. We have a 2010 Mastersbilt Smackdown with the wide right front 5010 model options with S7 spindles. We run a 3/8 mile banked track that is wide and sweeping at one end and has a tight corner on the other end. Starts tacky and the car is very good, by the end of the night it WILL NOT enter the corner with any speed at all. It feels like the car wants to skate especially on RR and we looped it twice on our own last night which has not happened in years. The car is really good from the middle off on throttle but is horrible on entry. I have tried by the book, I have tried suggestions from Masters, I have tried suggestions from Shorty who built the shocks, I have used some things we used to do on our Rockets. Nothing seems to help!
    Current Setup:
    Wheel Weights:
    LF: 540 RF: 485
    LR: 675 RR: 575
    100 lbs. bite
    54.5% left side
    54.8% rear
    Springs: LF500 ( have gone to 550 no help) RF375 ( have been at 400 before)
    LR 200 tried 250 no change RR 225 ( 250 last week, no change)
    5th coil-350 at 35 inches
    side to side 16 inches
    Bars (4holes on chassis)
    Left side lengths- LRU- 17 inches- 1 hole down from top RRU- 16.5 inches- 2 holes down
    LRB- 15.5 inches- 1 hole up from bottom RRB- 15 inches- bottom hole
    I have tried dummy shock and without- no significant change either way
    J bar is at 18 3/8 length
    2nd hole up on pinion (lower and it lifts LF really bad)
    8.5 inches up on frame
    LR limiter chain at 13 inches
    Ride Heights - LF 3.75 RF 3.5
    LR- wedge RR- 6
    I moved the angled fuel cell to the right as far as I could to get LS% down to 54.5. It was the the left as far as possible at first. I have tried an aggressive rebound RF package, and a mild shock package, same result.All birdcages and heims are new and are from Masters. Fresh low drag Franklin Rear
    Caster and Camber set from Masters Book
    When I add any more rake, the car lifts badly on LF. If I soften compression on RR it does the same.
    We have a 430 CI aluminum Motor with 825 HP. Bert Ball Spline and Carbon Fiber Shaft. Driver does tend to use go peddle like a switch and prefers the bottom groove. Any suggestions please post or PM. I have never asked for help on here but I thought maybe I am overlooking something. Thanks
  • dchamp3
    • 193
    We had the same problem with our car but its not a MasterSbilt ,I have had the same problem with it running the same springs you are i flopped the back springs but the 225 lr 200 rr dropped wedge to 60 lbs. and the car has ton side bite getting in now just something to think about. We also had one of those cars 09 and after 15 races the car started cracking around the welds on the rf a- arm area and the lr where your j-bar mounts to the frame .
    • keeks
      • Oct 2008
      • 687
      Just curious, what is an aggressive rebound? Fast, or slow? I would think you would want the rebound slow(higher number) on the right side to keep the weight shift hanging on the right in the slick. What about brake bias? Sticking front right caliper maybe?
        Why is only 1 bar at the standard length?
        • settler98
          • Oct 2012
          • 86
          I am sorry, i posted the wrong bar measurements. The left side are both set to standard length from Mastersbilt S7 setup book. The right side was set to book length and this week I shortened them each 1/2 inch to try to tighten entry. When I said aggressive shock I mean rf rebound at full +. So, again my fault in description, I guess no rebound would have been better description for rf.
            It sounds like something is preventing the car from getting over on the RR on entry.
            I would suggest taking the shocks and springs off and moving all suspension components through all possible ranges of motion. Something could be in a bind. Be sure that at all points of motion in the rear end, you can grab the bars and j-bar and rotate them freely. i.e. grab the bar and turn it like you would to lengthen or shorten it if you had the jam nuts loose. If you can't move it easily, that's bad. If you can't move it all, that's really bad.
            • racer241
              • Oct 2010
              • 57
              we run the same basic car, S7 front, we use alot less left side weight, like 53.6-53.8. had a hard time with entry until I got that left side weight down. Also, we have played around with fuel cells that get the fuel weight out of the tail a bit, that helped the car big time, we run top 3 almost every night since we did these things. We are on a soft rf though, so its a bit of a different setup. Have been running 275Rf with bump stop to cushion
              • MachineMasters
                • Oct 2010
                • 74
                6" right height on RR seems low..
                I've always been around 7 1/2".
                Does that sound right?
                • SLM98
                  • 407
                  Yep I think the book calls for 7 3/8". Whats your rear end side to side measurement?
                  • settler98
                    • Oct 2012
                    • 86
                    The side to side was 15 3/4 up until last week and then I pulled it to 16 to try to tighten up entry.
                      I didn't notice the 6" ride height until MBRacer pointed it out. That's way off. 7 3/8 is starting point.
                      Also, the LF ride height is a little high. Should be 3 1/2 baseline.
                      Let me ask you this...How much shock drop do you have on the RR and what kind of birdcages do you have?
                      • settler98
                        • Oct 2012
                        • 86
                        The birdcages are new this season and they are TWM Bearing Cages. I will check the RR shock drop today to be sure. Thanks for your suggestions, I really do appreciate it.
                        • tommy-gunn
                          • Dec 2011
                          • 16
                          I don't understand your rear ride heights. Your rr should be at 7 3/8 and your lr should be around 7 1/2 to 8 inches depending in wedge. But do not go over 8 inches on the lr!!
                          • jedclampit
                            • 613
                            Current Setup:
                            Wheel Weights:
                            LF: 540 RF: 485
                            LR: 675 RR: 575
                            100 lbs. bite
                            54.5% left side
                            54.8% rear
                            LR- wedge RR- 6
                            Try changing the driver if he has no throttle control !!!
                            • 01_4_life
                              • Oct 2012
                              • 23
                              throttle control
                              That's advice you don't here very often, but its often the BEST advice !!!!!!!!!
