CT525 power upgrade question
  • Dragoon55
    • Jun 2013
    • 240
    Just pondering options on a DLM engine package on a budget. Around me there are several series that allow the CT525 as an option or even as the required package. A couple of the actual "Open Comp" series allow the CT525 to be run, but they don't actually want it to win against the "Open Comp" stuff so they setup the rules to make it irrelevant with weight and spoiler rules that are equal to the open motors. Now in its "As Shipped" configuration(coil packs and control module) it makes I'm told 525HP and you can't do any modifications, fine. However if you strip the coil packs & control module and add a distributor and MSD I assume you can do whatever you want to it. So if you can do whatever, how much power is this engine capable of without having to replace all the internals, maybe just pistons, cam and some port work. I know the ZR1 Vette puts out 638HP Super charged in the same basic configuration, but how much power will it tolerate reliably? I'm not looking to cheat just to maximize this package on a budget. Any thoughts or advice welcome.
  • derricklong38
    • Jan 2009
    • 167
    the 638hp comes out of the LS9, which is a LS3 bore with a Supercharger.
    There is no need for a dist. if you can run coil packs.
    The LS Motors benefit from port work, but with the L92 type heads that come on the are pretty good. BUT there is alot to be gained in the top end, and pick up comp. numbers is big also.
    FWIW an LS7 block is 4.125 bore, match it with a 4.125 stroke crank, and no one would be none the wiser.
    only issue is the oiling system. It is turned by the crank at 1:1 speed, unlike a SBC, so you cant turn them to the moon
    • Dragoon55
      • Jun 2013
      • 240
      Originally posted by derricklong38 View Post
      the 638hp comes out of the LS9, which is a LS3 bore with a Supercharger. There is no need for a dist. if you can run coil packs. The LS Motors benefit from port work, but with the L92 type heads that come on the are pretty good. BUT there is alot to be gained in the top end, and pick up comp. numbers is big also. FWIW an LS7 block is 4.125 bore, match it with a 4.125 stroke crank, and no one would be none the wiser. only issue is the oiling system. It is turned by the crank at 1:1 speed, unlike a SBC, so you cant turn them to the moon
      Thanks for the info. I think you missed my point, I do NOT intend to cheat. I'll either run the CT525 as is, legally or dump the coil packs and module for a distributor. Reason being if you run under CT525 rules they allow no mods, but if you dump the coil packs & module you can do whatever you want to it and you have an all aluminum engine relatively cheap. I guess you could dump the factory oil pump and go dry sump as well if need be. I am curious how much power this block and rotating assembly can handle though...
      • dirty white boy
        • 1238
        seen quite a few handle 1200+ hp with turbos,...theres a few on here doing what your thinking an sure thay will reply soon as thay see it
        white trash motorsports
        • derricklong38
          • Jan 2009
          • 167
          You will not max out the block as far as HP in building a dlm engine. I have never seen someone come out with a hp # for the bottom end for oval type use. People are using the crank in 800+ hp apps, but most are using them in drag racing.
          as dwb said 4 digit power lvls are not uncommon on these engines.
          • Dragoon55
            • Jun 2013
            • 240
            Now are these CT525 type blocks or the LSX stuff?
            • derricklong38
              • Jan 2009
              • 167
              aluminum LS3 Blocks. The LSx stuff is overkill for what we need. The guys making HUGE numbers are putting in different sleeves, but the stock stuff is fine.
              • let-r-eat
                • 2319
                The block will handle the power. The heads can be worked to make power. Compression increase/cam/etc will all help. I could see 800 coming out of a combination with this engine but it won't come cheap. There is a reason why they haven't caught on yet. $$$$ and the type of power they make.
                BUCKLE UP NOW, YA HEAR?
                • hucktyson
                  • 1903
                  The people putting 1200 to the ground with 25 psi of boost and heads that flow 450 @ .700 are using RHS or world product war hawk blocks not stock LS blocks. The LSXblock is iron and heavy as hell but will hold 2000+ hp
                  • Dragoon55
                    • Jun 2013
                    • 240
                    Im really only interested in what can be accomplished with the CT525 package, but thanks for the info. What can be done with the stock package, ie block, heads and crank and what can be achieved??? Is 750HP too much to ask...
                    • Jake08
                      • 299
                      I have a ct 525 puts out 720 on Rayburn's Dyno complete with MSD $7000 3night since fresh.2174302277
                      • fwdbite
                        • Mar 2009
                        • 40
                        What kind of power will these blocks hold up to? I believe they are cast aluminum not billet.
                        • Dragoon55
                          • Jun 2013
                          • 240
                          Okay, so what are you saying?
                          • Egoracing
                            • 4852
                            Who makes a Billet aluminum block????
                            • derricklong38
                              • Jan 2009
                              • 167
                              LSM Systems, Dart has a program, Katech performance. Probably more.
                              ALOT of people use stock blocks, with a sleeve system from darton, or erl performance. These engines have problems with power adders, they hurt the sleeves.
