radiator
  • jbh25
    • 259
    radiator
    how are the late models mounting there radiators and where do u get the long springs. some pics would help also.
  • joedoozer
    • 745
    Mine just sits in saddles on the bottom. Here is a link for all the radiator hold down parts.
    PitStopUSA.com offers huge selection of circle track racing parts, drag racing parts, Truck and Off-Road parts, high performance parts and accessories. We have a huge selection of driver safety equipment including helmets, HANS Device, racing suits, racing shoes, racing gloves, seat belts and more.
    Crew Chief "Tip of the day":
    • jbh25
      • 259
      any pics anyone
      • racin6mod
        • 2172
        it's not easy to post photos anymore and most like me don't want to screw with it now.
        • mab18
          • Aug 2009
          • 41
          You can get the long springs from your local big truck supply store. Throttle return springs for a old International work just fine
          • hsracer
            • Feb 2011
            • 33
            Use threaded rod instead of the long springs. On a rough track the rad will move around with the springs. My friend had springs and the fan went through the rad because of the springs.
            • dzona99z
              • Dec 2010
              • 27
              1/4 threaded rod works fine.
              • Vaughn89
                • May 2010
                • 40
                This is my first year racing and my first time putting a late model together, I have a 05 rayburn and I used 2"x14"x1/8" aluminum flat bar for my straps to support the top of my radiator (I bought a 3 foot stick of it at tractor supply co. for like $12)...I found a peice of aluminum channel that was wide and long enough to sit inside of the top part of my radiator and I riveted the straps to the radiator, leaving around an inch or so hanging in front of my radiator so i could have somthing to hook my springs into...as far as the springs go, I found some at my local parts store, I know advance auto parts has like a 6 pack of those long springs for like $8. make sure you put around the same amount of tension on both springs. Hope this helps!
