I am installing a set of bearing birdcages on a 4 bar car and have questions as to exactly where to line them up in relation to the 4 bar mounts on the chassis. My old birdcages had the option to float the caliper bracket on the birdcage. I had the brake brackets clamped so the caliper brackets served as the retainer clamp on the brake side of the cage. The new ones have the bearings towards the center on both sides. There is several inches of space between the caliper clamp bracket and the cage now. Should I set them up using the rotors as a measuring point and measure back to the trailing arm mount? This is a GRT type car with 34-35 tubes. I have seen some cars with the 4 bars angled when static. With all the potentialy different mounting locations is this an area for expeirment or is the location pretty standard?
Thanks
Thanks
