2005 GRT floating X - car is fast and have a couple feature wins but I am looking for a little more to adjust and fine tune the setup. Would like to tighten entry a little all night and entry/middle as the night goes on without loosening exit. Don't want to tighten entry/middle at the expense of exit. WE are only allowed to run LM40's
1st - I am thinking of changing the LF spring to help tighten the car going into the corner...
What would be a good starting point for going up in spring rate...25#? 50#?
Will this only effect corner entry?
2nd - I am thinking of shortening the right side rear bars...
Do you shorten only the lower bar or both?
How much should I try shortening it?
3rd - What about wheel offset...I mounted a 6" for the RR and a 3" for the LR with an 1 3/4 stagger that I am also thinking of trying. I go from 5" of stagger at the beginning of the night to 2-3" come feature time but keep 5" offsets on both.
Try both at once or only one or the other?
~Thanks~
~Thanks~
