2010 rayburn 4 bar....
  • jsw444
    • Apr 2008
    • 68
    need more forward drive in the slick........650lf....350 rf....225 lr.....250 rr...panard bar 10.5 inchs on frame 1 inch below pinion.....55 left...56 rear....120lbs bite.....car gets in good, rotates center great,just no drive off......any suggestions....we are on american racer md56 tire as well.....
  • janke27x
    • Dec 2011
    • 107
    if its not a crate motor try a 400 on the rf and a 175 on the left rear.
    • powerslide
      • 2696
      where is the lift arm? what shock/spring?
      • jsw444
        • Apr 2008
        • 68
        thanks guys for the reply.....5th coil i think is at 34 inchs with a 3comp 8 rebound......350 spring.....
        i thought about trying to stiffen rf my self...thought maybe there was too much rear steer.....the track went tacky since i posted this so havent tried it yet.....now the car owner is buying a 2014 4 bar rayburn.......need to know which is better and why......underslung or over rail......
        • stevo
          • Jun 2008
          • 622
          Neither will be better just cause of the bars,under a bit stronger over more room to work.
