GRT tie rods....what length?
  • Plantintaters
    • 160
    I am playing with lower arm lengths on the right front of a 2000 GRT. What approximate length should the right tie rod be at with a 17 5/8 lower? I built a lower that is 19 1/4 that I want to try but am unsure what length to start with. GRT gives a length for the left front so should I just make the right at what ever I need to get the toe to work out?
  • SS Motorsports
    • Sep 2008
    • 431
    Yes the right is whatever you end up with to get the toe right.
    • 7uptruckracer
      Go through your bumpsteer for sure though because it will change!
        Just my opinion but I would get the right side correct for bump steer and then set toe with the left. Right side bump steer is way more important than left side I think. But I could be wrong.
        • Plantintaters
          • 160
          Thanks for the quick response. I will get the bump under controll before I go to the track. I agree with you that the right side bump is important and I am an old asphalt racer so I have played with it many times. As long as it don't bump in any we'll be ok. They all bump a little, you just need to take controll of which direction it bumps and dail it in from there. Thanks
          Let go play "race"
