Of course, the inspection plug is stripped, so I can't check it like the website says. How much do I need to put in? It was empty when I bought the car. Thanks.
How much gear oil in a Winters?
Gotta have a good eye but 2in.below axle centerline look through inspection hole.Almost 4qt i believe.Also the plug on the gear cavity can be used.Put Mystic in it.
Here's info right out of the Winter's catalog:Attached FilesCrewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
