Shock Tech Q&A
  • PenskeShocks
    • Sep 2013
    • 51
    Shock Tech Q&A
    Please post any shock related questions. Penske Shocks is making a big push into LateModels and our techs are here to help you with any shock related questions or comments...we will have 2 technicians in Knoxville next week, we will be working with Scott Bloomquist, come by and see us.
  • 37mod
    • 88
    if the 5th coil shock has to an extreme amount of rebound will it cause a push on a momentum track by not letting the front settle?
    • PenskeShocks
      • Sep 2013
      • 51
      Definitely, we typically run very little to no rebound on the 5th. Generally the 5th is a great shock to control on throttle grip.
      • racin6mod
        • 2172
        how much to rebuild a lr gas shock mine has a ding in the shaft and a leaking seal.
        • zeroracing
          • 1014
          What is the biggest mistake or false trend that you see late model racers doing?
          i.e. Too high rebound one wheel, too low compression, vise versa, gas pressure mistakes...
          • JR. MECHANIC
            • 253
            Are you sure you two are talking about the same shock.... I believe he is asking about the shock on the lift arm.... Typically 3 compression, 3-7 range on rebound depending on track condition. It looks like penske is talking about the damper on top of the housing.....
            • 37mod
              • 88
              I was referring to the shock on the lift arm.
              thanks for the reply.
              • stevo
                • Jun 2008
                • 622
                Bloomquist runs a shock on top of the rear end,feels like 90/10 but most don't so if most don't run one on top should the 5th coil be higher number rebound,if not will car not be loose?
                • JR. MECHANIC
                  • 253
                  Stevo, adding more rebound to the 5th coil shock will tighten entry. One cannot say that if you don't run a top shock, that you have to add more rebound to the 5th coil. Let the stopwatch determine that.
                  Brandon Dierlam
                  MBR (mark bush racing)
                  Shock guru
                  • stevo
                    • Jun 2008
                    • 622
                    I was think they did the same thing,
                    • JR. MECHANIC
                      • 253
                      Simplying adding a 90/10 will tighten entry also
                      • stevo
                        • Jun 2008
                        • 622
                        So is this doing the same thing? Adding rebound on 5th as putting 90/10 also some say anything on rearend takes away drive,and how did Bloomquist do with these shock guys i see there not here anymore.
                        • JR. MECHANIC
                          • 253
                          You see who isnt here anymore? The only way a top shock can take away drive is if there is rebound control or it is topping out under acceleration
                          • mab475
                            • Sep 2010
                            • 165
                            I believe he is referring to Penske Shocks. They started the thread wanting questions from everybody and has only been on once since. If this is any indication of their service then I'm sure guys will just stick with what they have and the shock guys they have.
                            • PenskeShocks
                              • Sep 2013
                              • 51
                              Guys, sorry I haven't been on lately.. At Knoxville currently. I will post back to all your questions Monday..As for the rebuild..$50 per shock, includes post Dyno, new shims, oil, and seals...
