Got a 03 grt has basic set up on it from grt specs. 500 lf 350 rf 250 lr 225 rr 325 on 5th shock 4 bars in spec location lower rr is up in 2nd hole tho. Lights up tires from corner to corner specially on dry slick.. Even when.you ease on the throttle itll light em up. any suggestions to fix this? Thanks
Grt no forward bite!
200's in the rear and 130ish bite but most of your problem is the 5th around 250 give or take 25 lbs and around 35" out is your biggest red flagOriginally posted by racert22 View PostGot a 03 grt has basic set up on it from grt specs. 500 lf 350 rf 250 lr 225 rr 325 on 5th shock 4 bars in spec location lower rr is up in 2nd hole tho. Lights up tires from corner to corner specially on dry slick.. Even when.you ease on the throttle itll light em up. any suggestions to fix this? Thanks
