has anyone used the rack with bolts that bolt tie to rack and does the right inner bolt on top of rack what spacers for inner and outter.because i have a new one just changing chassis
gen-x rack ?
i understand that i have the other rack and just seeing if anyone has used these rack yet and what the new bumpsteer spacer are and do you mount the right inner tie rod on top of rack
The cross member was raised so the rack is moved up. If anything you would need to be mounted to the bottom of you rack. Going to the bottom probably has you lower than your supposed to be so you may have to shim the outer pick up down further. The only way to know for sure is to measure your rack and a center pull and shim the difference.
