Transponder
  • keeks
    • Oct 2008
    • 687
    Transponder
    I have been toying with the idea of buying a transponder instead of renting every week.
    This is going to sound dumb, but will the new mini transponders that are for RC racing work at the track? They are 1/4 the cost.
    I'm sure the answer is no. But smaller and lighter usually means more expensive. Or is it just less technology in that smaller package? Or less power?
  • TALON75
    • 887
    I dont believe they will, but one for gokarting will. I think the go kart ones are designed for speeds under 100mph, and the racecar ones are for over 100mph. A buddy uses the go kart one on his modified without issue.
    www.RACE91.com
    • JustAddDirt
      • 1893
      power source is the problem with the R/C transponder. plus signal strength.
      Typically R/C stuff, the scoring loop, and the transponder will be closer together (ride height of cars or trucks, probably won't be over a couple inches apart.)
      • keeks
        • Oct 2008
        • 687
        Great info! Thanks.
        • zeroracing
          • 1014
          Glad I race where they give you one, and just don't give you your pay till you check it back in. Scoring is the cost of running a track, either a person or person and transponder, not a race car item to rent... That would be frustrating.
          • keeks
            • Oct 2008
            • 687
            Payout? What's that? Don't even get me started.
            • zeroracing
              • 1014
              It's the punch line to the joke known as racing.
