front ride heights
  • Rocket10t
    • Jul 2013
    • 2
    front ride heights
    If you raised your LF ride height ( lets say went from 3" to 3.5" ) would that help keep the weight over on the RF for dry slick. Same as putting tilt in your car OR is it better to keep the LF ride height lower . I know that the LR ( tilt in car ) helps keep the weight on the RF for slick . As well as a good shock tied down and soft spring to keep it there. So what about the LF ?. where does that weight transition to - RR ?.Also what about weight placement on the front end. Where is a good place to add weight to keep weight on the RF ( if I wanted to add weight to front end ). Just struggling with weight transitions and placement.
  • zeke23z
    • 271
    Weight transfer. Under braking rear to front stiffer spring getting more.Turning Left side to right side.Acceleration front to rear.What handling problem are you having?If you are just putting turns in the left rear you are adding wedge looser in tighter off.And weight can never transfer from lf to rr or diagnally in any way.Stiffer spring gets the weight always.Use your shocks to try and time weight transfer.
    www.nanooklodge.com
