Grt
  • sgart35
    • Oct 2007
    • 44
    Ok, that explains it well. We have a couple practice days coming up so I'm going to take into account all things suggested and see what we can accomplish.
    • Mantachie Missile
      • Aug 2010
      • 45
      There's a lot more questions that need to be answered before you can really determine the cause of your problem. You're saying its over rotating, where's your bar angles? Are you indexed anywhere? How much are you leading the lr? I agree there needs to be done spring changes but with the car over rotating on throttle it sounds like to much rear steer. Jmo
      • lcpestka
        • Aug 2007
        • 144
        There is a happy medium in everything, on a GRT latemodel, based on where the spring is located from the wheel in comparison to a Rocket or Mastersbuilt is further away. GRT = 7.75 from the rotor to the center of the spring RR, on a Rocket it is 7.25. So eveything is a system and works together, if your RR isn't making enough sidebite on Cornner entry it won't trip the RF down and elevate the LR which in turn can cause a push in the center which seems to describe the situation of the original post. Remember also, that when you change bar angles you also change the spring rate cause it effects the motion ratio, pick your bar angles and stay with them, work the springs and shock and you will have way more sucess.
        • grt74
          • Jul 2009
          • 1380
          Originally posted by sgart35 View Post
          Thanks for all of the responses guys. I'm sorry it's taken so long for me to respond to this thread, got busy through the holiday season and it slipped my mind. But back to the topic, we had a race this past weekend and went a little harder on the right front than we were running but still had the same issue. It seems as though when entering the corner the car is good and actually plants the right side tires but with any application of the throttle, the car seems to want to over-rotate and doesn't have any drive off. Started off with bars in standard location and the rest of the setup was basically the same. Let me know if you guys have any more ideas. Thanks again.
          2 things that come to mind,spring or rebound on the rf,dont worry about the # just keep adding spring rate until she pushes,or if you have a ton of rebound back it off some,good luck,hope this helped
          when it does push just back up a little of what you have done
