Just went to hook up an AUTOMETER MEMORY PRO COMP TACHOMETER 6821 0-10000 RPM. Usually there are 4 wires Green (MSD), Black (GRD), White (LIGHT) and Red (POWER). This tach has a Red, White, Black and then a 2wire wire looks light a lamp cord. 1 wire is black the other is black with white stripe. Any ideas?
Auto Meter Tach
So the double black can be used as a green wire? Going to an inductive pick up, this would be the msd correct? Or am i reading wrong?Originally posted by MM90 View Post
I don't think so. It sounds to me like you have the wrong tach for your application. It sounds like you have a tach for a magneto not a distributor.Originally posted by bigk44 View PostSo the double black can be used as a green wire? Going to an inductive pick up, this would be the msd correct? Or am i reading wrong?Crewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
Looks like you correct BigBlueFord.Originally posted by BigBlueFord View PostI don't think so. It sounds to me like you have the wrong tach for your application. It sounds like you have a tach for a magneto not a distributor.
Anyone need a tach for a Magneto. $125.00 shipped to your door
