Grt chassis number
  • koller44
    • Jan 2010
    • 20
    Grt chassis number
    Where are the chassis numbers located on a 07 Grt? Looked around the car and couldn't find one.
  • RACR_73s
    • 879
    On my 05 it is in the left side motor mount and I think it was in the same place on an 04 that I used to drive. If they changed the mount the new one will not come with it...had to change the one on the 04.
    • koller44
      • Jan 2010
      • 20
      Thanks for the help although I wasn't able to find any markings on the motor mount, your explanation of why i might not made perfect sense.
      • sj valley dave
        • 1016
        Ours is on the left front frame near the LF motor mount also...
        • merc123
          • 1261
          You can't miss them on the mounts. It's welded, not up a small punched number.
          Web: http://www.t17.co
          • shopteacher
            • Dec 2013
            • 37
            Impossible to miss if it is there. As someone else mentioned GRT actually wrote out the number in weld. On older cars it was on the LF frame rail and then was relocated to the left engine mount. Possible the mount was replaced and it was not added back on to the new mount or that the car was clipped.
