I am looking at a set of front brake calipers but need to educate myself first, so I came here for my "education." They are a set of Wilwood forged narrow Dynalights and one of them has a 1.0 piston and the other is a 2.0. According to the guy one is marked LF and one RF (I don't know which is marked what). My current rear brake setup has US Brake f88i calipers which are a staggered piston caliper with 1.88 & 1.62 pistons and I don't know which compound the pads are. Last year I had a Grt LF caliper and a Rayburn RF caliper and that is about all I can tell you about them other than the LF must have been braking much harder as it wore the rotor thin and the pads to nothing. It seemed like I could never tighten up entry even with all front brake (could this be a reason why?).
1) Which one of the Wilwood goes where and why?
2) Which brake pads should I use...Front? Rear?
3) Should I use these two different sets together?
4) How do different size pistons affect braking?
Any other info that might be helpful is also appreciated. Budget is a big consideration in the decision, but not the only. Running a limited class and payout is not that good so buying all new stuff is not an option.
~Thanks~
~Thanks~
