4/7 Swap Headers
  • kevpow
    • Feb 2012
    • 174
    4/7 Swap Headers
    When running an engine that has the 4/7 cam set up, do you have to run different headers? Thanks
    I wanna go Fast!!!
  • triple0racing
    • Dec 2013
    • 3
    Only if you are running a tri y headers
    • FlatTire
      • 560
      no. you can run tri-y or non tri-y with a 4-7 swap cam. The dyno will help you make the correct choice.
      • swingarm4life
        • Apr 2008
        • 155
        If you run tri-y headers, they have to be built for a swap cam. Conventional headers will work fine.
        • Brian Gray
          • Feb 2012
          • 1102
          either way the numbers arent much different from conventional headers if you run std seq. tri ys.
          if your asking will it hurt the engine the answer is no
          Shocks by BGR army
