wide 5 load tire?
  • tn_dude05
    • 70
    wide 5 load tire?
    Does anybody know if a older vw wide 5 looking rim will work as a load tire /rim? Sure looks the same, Or what do you use?
  • shopteacher
    • Dec 2013
    • 37
    Don't know of one from a VW, some of the older 50's-60's Ford heavy trucks had the same pattern as a W5 though. Little pricey but Bassett sells a 15x8 W5 that would work as a loading wheel for most.http://www.speedwaymotors.com/Basset...eel,73218.html
    • spray004
      • Jul 2012
      • 74
      No old VW wheels wont work. I bought my from Tru Wheel here in Alabama. It was like $55 or $60 shipped and they are custom made. You pick the size and backspacing and color. I couldn't find a used one anywhere around here.
        Back in the day, we made our own from a damaged wheel. Have someone cut it on a lathe and then get it welded up.
        • jedclampit
          • 613
          FWD gm 2 door cars from the late 70,s , olds toronado,buick riveria, eldorado, zero offset and enuff meat to drill holes where the wide 5 lugs are located....good luck finding them....
          thats what I remember using........ way back when...if I remeber correctly
          • stevo
            • Jun 2008
            • 622
            House trailer wheels same pattern as 32 Ford
            • spray004
              • Jul 2012
              • 74
              I think most mobile home wheels are 14.5" wheels. Might be hard to find a good used tire in that size.
              • shopteacher
                • Dec 2013
                • 37
                I assumed there would be a cheaper option than Bassett. That's a good price, worth that compared to the hassel of making or modifying something.
                • spray004
                  • Jul 2012
                  • 74
                  Yeah I think Summit has a wheel that's a little bit cheaper but it was a 2 month back order so I called Tru Wheel. I've had good luck with them in the past.
                  • LM90
                    • 210
                    I have a weld wide five alum seven inch wheel with tire that we used $75.00 814-374-4410
                    • sj valley dave
                      • 1016
                      We have 2 old Ford rims wheels that are 4" wide..Early 1930's or there abouts...Got them for nothing with tires that hold air..
                        On a bit of a side note, the Wide-5 hub design itself actually originates from those old Ford trucks. Not just the bolt pattern, but the width, bearing configuration, locking mechanism, etc.
                        • 700horsepower
                          • 191
                          Yes.And the bolt pattern only lasted 1 or 2 years as a Ford wheel pattern (1937-39 I think) but has lasted this long in the racing circles. The original idea was to save money by bolting the rim to the brake drum to make the rim lighter and cheaper to build.
                          • ALF401
                            • 164
                            I had two old carbon fiber wheels with the outer portions damaged. They were bolted to an aluminum back half. I bolter the two back halves together and silicone the center. 8" wide and worked great!
                            • Lt.Stryker
                              • Jan 2014
                              • 70
                              15x8 wide 5 load wheels from Smiley's Racing... $60.17. http://www.smileysracing.com/shoppin....aspx?i=118365 Then grab a couple of narrow 15" tires from your local used tire shop.
