Rear end damper shock
  • spray004
    • Jul 2012
    • 74
    I've got an '05 TNT that I bought this past fall. The previous owner has a damper shock mounted to the top of the rear end and the chassis. I haven't really seen this set up on other late models. Is this common or can someone explain why one would do this? We have a 5th and 6th coil on the lift bar as well.
  • grt74
    • Jul 2009
    • 1380
    that used to be done alot,but with todays 5th coil shocks its just not needed anymore,it tightens entry a ton
    • spray004
      • Jul 2012
      • 74
      Would it be better suited to be used as a LRF shock?
      • grt74
        • Jul 2009
        • 1380
        depending on what you are doing it could be used there, most 5th coil shocks are rebound adjustable so you dont need a shock over the rear end,just make sure you know the valving so you know what your using,that way if you do use it somewhere and dont like it you know which way to go(food for thought)also make sure its a 9"shock if you use it on the lrf,good luck,hope i helped
          And put a 2" extender on it if you're going to run it in front of the LR.
