need new tubes for a rocket
  • steelkiwi75
    • 366
    I bought a 03 rocket.want to use the center section out of my old warrior. I know I need 33 and 36 in. Axles. But what are the tube lengths?
  • AmickRacing
    • 236
    Add 5" to the axle length for the correct tube length
    Home Page
    http://www.AmickRacing.com
      The tube is 6 inches SHORTER (not longer) than the axle. The tube can't be longer than the axle.
      This is for a Winters but I'm pretty sure all the brands are pretty much the same on this.
      • Brian Gray
        • Feb 2012
        • 1102
        the warrior rear should be the same you might want to check and make sure your measuring correct
        Shocks by BGR army
        • steelkiwi75
          • 366
          You are correct about the right side 36 but the left on Warrior is 32. And rocket needs to be 33.
          • toloud
            • Sep 2012
            • 24
            tube length
            Get a 1" wheel spacer. A lot of newer rockets come with the shorter tube and a spacer.
            • Brian Gray
              • Feb 2012
              • 1102
              my new rocket car the rear is shorter . they changed some things the last 2 years
              Shocks by BGR army
              • AmickRacing
                • 236
                whoops! Sorry about that guys, I shouldn't post after being awake that long lol
                I ran across a picture on pitstop usa's site that showed the 5" difference. Thanks for the clarification Matt!
                Home Page
                • steelkiwi75
                  • 366
                  If I use the 1 inch spacer, will I be able to get my bird cage in the proper place?
