valve cover issue
  • jfleming
    • 200
    valve cover issue
    Valve Covers 18 degree wide body
    Does anyone have a suggestion on a good set of valve covers that are the wide body or sometimes referred to as the inverted flange for a stand chevy bolt pattern. I am looking for something that will clear the jesel rocker system on a 18 degree head. Need extra room
    thanks
  • BigBlueFord
    • 189
    Here's a link to Dart's cast aluminum inverted flange valve covers:
    http://www.dartheads.com/products/ac...cover-set.html
    Crewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
    • joedoozer
      • 745
      Here are some fabricated ones.
      http://www.speedwaymotors.com/S-B-Ch...ubes,9005.html
      Crew Chief "Tip of the day":
      • jfleming
        • 200
        thanks for the reply, I like the dart ones but they dont have the breather tubes, Have you used the fabricated one? if so how is the quality
        thanks
        • BigBlueFord
          • 189
          We added breather tubes to the Dart valve covers (tubes bought from speedway motors)....We tried the fabricated ones, they were okay for a while but eventually the flange distorted and they start leaking. The Dart valve covers are lot more substantially and less likely to deformed.
          • jfleming
            • 200
            where you just able to weld in the tubes from speedway?
            • BigBlueFord
              • 189
              Valve cover and tubes are both aluminum.....so just TIG weld them. Use a hole saw to drill hole halfway between mounting bolts.
              • BigBlueFord
                • 189
                Here's a couple valve cover pictures:
                • jfleming
                  • 200
                  where did you get that weld in bung for the oil fill?
                  thanks
                  • BigBlueFord
                    • 189
                    I got the breather and the oil fill bung from Speedway:
                    Here's a couple of links:
                    Oil Fill Cap:
                    http://www.speedwaymotors.com/Weld-o...-Cap,1608.html
                    Weld-on Valve Cover Breather:
                    http://www.speedwaymotors.com/Weld-I...Sets,1879.html
                    Speedway has both aluminum and steel breather kits, make sure you order the aluminum version.
