Torque specs for Wilwood hubs?
  • fast14
    • May 2008
    • 62
    How much should you torque down a Wilwood wide 5 hub? Any help appreciated. Thanks!
  • Matt49
    • 3123
    If you're talking about the spindle nut, you shouldn't. Just tighten to finger tight and make sure you don't have end-play (in and out). Then put your lock ring in place. Too much pre-load will damage the bearing.
    If you're talking about the drive flange bolts, it's 40-45 ft.lbs. then safety wire them properly.
