12" x 5" offset Wheel...How will it effect the car?
  • RACR_73s
    • 879
    I have a 12" beadlock wheel w/ 5" BS that I bought from someone (neither one of us realized it) and would like to know if I keep it...
    1) How will it effect the handling of the car?
    2) Which corner can I use it on?
    3) Any pro's/con's?
    Should I return it? (Only paid $75 and he will refund)
    ~Thanks~
  • RACR_73s
    • 879
    Sorry, I should have stated...the difference in a 12" as opposed to the 14" that I normally run?
    ~Thanks~
    • Brian Gray
      • Feb 2012
      • 1102
      It can be used as a tuning option for sure and people do. But how it changes the car would take way too long to explain.
      Use it to manipulate your tires contact patch and flex ability is the best I can tell you here.
      Shocks by BGR army
      • keeks
        • Oct 2008
        • 687
        Pretty sure you are going to see an increased rollout on your tire. Could maybe be used to fine tune stagger?
        • RACR_73s
          • 879
          Brian, I am not smart enough to get into all the engineering aspects...so can you dummy it down for me and just point me in the right direction?
          Which corners do you use it on?
          What should I look for it to do to the car as far as tighten or loosen it?
          I believe it stiffens the sidewall of the tire, does this effect the spring rate? Stiffen?
          I noticed the difference because it was laying next to a 14" wheel and it looks like it is a 7" backspace...is this just a trick on the eyes or does it actually some what work like a different backspace?
          • Brian Gray
            • Feb 2012
            • 1102
            It depends on what tire you use. I was being as lay as possible.
            You can use rim width to manipulate your tires . use it anywhere you need to change contact patch or flexibility. Its a good way to get some more stagger. Run lower air pressure and make the tire more flexible. I have a few 12s and I use them time to time at any corner
            Shocks by BGR army
            • Brian Gray
              • Feb 2012
              • 1102
              It will also help the tire build heat. These types of changes can effect track width and alignments so keep that in mind when making changes to rim width
              Shocks by BGR army
              • RACR_73s
                • 879
                Ok, thanks for taking the time to respond.
                • RACR_73s
                  • 879
                  ????ToTheTop???
