Over the last several days, I been trying to take these old tires off of the weld rims. Its highly impossible after I bent 2 handles on 2 tire breakers. I went to two service stations and they told me they do not have the right adapter for the wide 5 rims. Anyone have suggestions?
Taking tires off the rim
Spray penetrating lube around the beads let sit then heat the inside of the wheel with a propane torch around the bead area. Then they will pop off easily.
I agree with wisdirtfan... propane torch, carefully heat the aluminum wheel at the bead area inside the wheel, not on the lip you will soften the lip and bend it too easily. Works every time for me even on the most stubborn ones... even on my modified steel wheels with soft sidewall tires that won't break the bead seat.
I had this happen on valken and older weld wheels. Heating the bead and penetrating oil worked like a charm. Btw I will never buy valken wheels again we got a deal on them when we started and they are so soft the slightest bump into anything and they are bent. I guess that's what you get for buying Chinese wheels lol.
