Bert Gen II transmission
  • hoofhearted
    • Sep 2008
    • 19
    Transmission not disengaging when clutch pedal is released in reverse and low gear, just keeps trying to pull. Never had anything like this happen with old style bert, any help would be appreciated.
    Thanks
  • JustAddDirt
    • 1893
    is it new?
    it has a band in it that engages low and reverse.
    it has a removable block on the side were your clutch line goes in. it has a plunger there that when petal is pushed, it moves the plunger, tightens band up, moves car.
    on the back side of the plunger it has a rod on it that connects it to the band, when rebuilding mine, I had to take off about 1/4 +- off the new plunger so it did not engage the band.
    Found that the plunger and rod assembly is made, and it has to have a the length adjusted....per Bert. They told me what to look for and what it would take to fix it.
    • keeks
      • Oct 2008
      • 687
      So there is no clutch in it now? It's the band instead? Just curious.
      • JCSullivan00
        • 1418
        Talked to a rep at PRI and they said to make sure the shifter is properly aligned. We found that ours was out of whack and caused similar issues to what you are having. I really can't remember what was said, but it may be worth checking into with them.
        • lazermod3
          • Jan 2008
          • 1910
          The alignment of the shifting lever is paramount,and will cause the transmission to not operate properly,if not correct.
          you just got greased
          http://www.goddardwarrior.net
            That's right. No more clutch pack/discs. It's a band that goes around a drum basically.
            • JustAddDirt
              • 1893
              it has a band, and hub with planetary gear set like an automatic transmission has.
              when transmission is in low and reverse it runs through the band and planetary. pushing in clutch petal tightens the band around planetary, and car moves.
              very simple, but if band is too tight on planetary hub, it will want to move, without any clutch petal imput.
              • Brian Gray
                • Feb 2012
                • 1102
                Have you replaced the clutch band? If so give us a call I can guide you through getting it adjusted back in.
                I have came across this issue with transmission's that people have replaced bands in.
                Shocks by BGR army
                • crate late
                  • Jun 2009
                  • 137
                  Mine had the same problem and it was the band. The clutch material had broken loose off the band and and was dragging on the drum inside. Took it apart and replaced the band and it was good to go again
                  • Jim11h
                    • 1501
                    New band last season new sun gear & selector this season. Won't stay in low now. Hard to find low unless put into reverse then back to low gear. Making tough getting thru pits.....any ideas? Thanks y'all
                      • 2019
                      The teeth for low gear are super narrow (like 3/16th wide) when the teeth get rounded some it pushes the coupler forward or back and un-egauges when you apply the clutch or torque to the trans.
                      put in first gear and apply the clutch and hold the shifter, if you feel it push the shifter that is what it's doing. So it's either adjusted wrong (shifter rod length) or the teeth are rounded and it's never gonna stay in gear.
                      • Jim11h
                        • 1501
                        Worked fine last year and just took to have looked at, sun gear had wear so he tried cleaning up to get thru season figuring save till next year. Put in and wouldn't work so adjusted shifter thinking problem is. Since gears replaced and been thru spectrum of shifter length. I put in drive and adjusted rod accordingly, is there better way? Hindsight should left rod alone and pulled to replace gears. He's learned that when wear just replace, ain't no saving them. Thanks for help billet
                          • 2019
                          Personally I think setting rod with shifter in first is the better way, then make sure the shifter lever arm isn't hitting the slot of the base when in the other gears like high.
                          • Jim11h
                            • 1501
                            Your way worked better, appreciate help
