Need to get springs for an over rail swing arm car with a limited steel motor. Any help appreciated!
recomended spring length/rate for swing arm set up
Assuming a true swing arm (all springs mounted on arms)Originally posted by donkypunch4u View PostNeed to get springs for an over rail swing arm car with a limited steel motor. Any help appreciated!
lf - 500 to 650 rf- 500
lr 300 to 400 rr 350 to 400
You can run 12" springs everywhere.
With the linear behavior of the suspension, you can make large spring rate changes. You may need a very stiff lf to tighten entry depending on laydown shocks and other factors.Modern Day Spec Wedge Racing
