Caliper mounts
  • keeks
    • Oct 2008
    • 687
    Caliper mounts
    Just mounting up some new birdcages. The last set had the caliper mounted to the cage. This set has separate caliper mounts.
    Should I drill and tap the tube? I would assume the clamping force alone would not be enough? Or just drill the tube? Does it need to be tapped?
    Thanks.
    Thanks.
    Drill and tap is the best way. I have gotten away with just dimpling the tube and using a set screw, but that is being awful trusting.
    • keeks
      • Oct 2008
      • 687
      Nice! Thanks!
      • hpmaster
        • Aug 2009
        • 1088
        I have always just drilled them and had no problems.
        • JTSjet
          • Mar 2010
          • 272
          Thanks.
          Drill AND Tap the tube!! tap the bracket and the axle tube as one continuous thread to eleminate any slop. use a minimum of 3/8 bolts, 7/16 is best - 1/2" starts to compromise the tube integrity.
          i have seen 3/8 bolts installed properly and still shear off - heavy track on the brakes hard to avoid a crash. in most cases you'll be fine but if it cuts loose it might end your night.
          • Lizardracing
            • 839
            You can always use 3/8 bolts and do both sides of the tube. That would be stronger than one 1/2" bolt.
