Is there any break loss in switching from a 1.125 rotor to and .810? Is there any other advantages other than less rotating rate?
Switching to .810 rotors
I have run the .380 rotors for years. Bought a car with them and saw no reason to switch. They wear very well.Originally posted by LM14 View PostDo you run long races? We went to .380 drilled rotors and lost no braking. We seldom ran more than 25 lap features with an occasional 40 thrown in. You may need to rethink your pad combination.
SPark
Larger diameter will increase braking force if you move the calipers to use it.Originally posted by DGI View PostWe run 25 to 30 lap races. Would you want to run a softer pad combination? Will my existing caliper mounts work on the .810 calipers? Reason I ask is the .810 are larger in diameter than the 1.125 rotorsModern Day Spec Wedge Racing
I was considering going from the 1.25to the .380 s also, would just spacing pads in the caliper be adequate?
