1060 or 1061 with drysump and cooler ???
Oil filter?
not sure what filter those are but anything along the line of a fram hp6 is going to work. you dont want a filter that doesnt flow at least as much as the line you are feeding the engine with. keep in mind you will loose some flow through the cooler so my opinion is larger openings is better.Shocks by BGR army
What is the difference between Wix 51061R and Wix 51222R? ~Thanks~
The 51061R is smaller than the 51222R. 51061R/51060R is made for a 350 stock block chevy mounted in stock location. Flows 28gpm and rated at 61 micron. The thread on this is 13/16-16. The 51222R is common for a remote mounted filter on a dry sump system. The thread on this is 1 1/2 - 12. This is a "large" filter. To go from a Wix part # to a Napa part # on just about any filter, drop the "5".Last edited by FlatTire; 04-28-2014, 11:34 AM.
