What would the tire rod lengths be? 15" 14" or 16"13" never ran a 19.75 rack always 18.25 but got to run what j have
black front end rocket w 19.75 rack
I'd park it before I put the wrong length rack in it. Especially off by that much. You're going to have ferocious bump steer issues...possibly to the point of being dangerous to drive.Originally posted by stehle View PostWhat would the tire rod lengths be? 15" 14" or 16"13" never ran a 19.75 rack always 18.25 but got to run what j have
Matt is right. IF you are run a rack and inch and half different than the spacing of the correct rack you will have all sorts of bump steer. Not saying you couldn't fix it to some extent but if you did you very well could run into clearance issues when you got done. Look around and get the right rack.
19 3/4" is the correct rack for a black front rocket. It should use a 12" left side tube and a 16" right side tube. The right side should be set to 19 1/4"
