Wissota Tires
  • keeks
    • Oct 2008
    • 687
    Wissota Tires
    Do any of you Wissota guys know what the difference between the WRS-2 D-55 and the WRS D-55? they say you can only use the WRS on the right rear, reasoning?
  • zeke23z
    • 271
    Different tread patern
    www.nanooklodge.com
    • wisdirtfan
      • Oct 2013
      • 94
      The wrs is a little larger also but the main difference is it comes in large square block instead of the little blocks of the wrs-2
      • KynetixSolutions
        • Mar 2014
        • 60
        The big block tire compared to the WRS-2 will not fire as quick. They will tell you its the same rubber but it is not, can't be just from a physics point a view. For more help you can call 618-304-2674
