steering trouble on rocket
  • monster777
    • Jul 2011
    • 41
    When coming off the corner and turning slightly to the right to drift up the track the car will dart hard right erraticly .not all the time and sometimes worse than others . I've checked everything I can think of for binding and measurements seem to be correct.any ideas ????
  • hucktyson
    • 1903
    It probably has a sweet rack and servo in it. Call Tony Woodward and the problem will go away unless you have bent spindles or something
    • FlatTire
      • 560
      Likely a rack issue. Make sure your caster is correct.
      • monster777
        • Jul 2011
        • 41
        Caster is correct. Rack seems to work fine otherwise. Any way to check it to be sure ?
        • EAMShater
          • Aug 2008
          • 138
          Have you checked the bump steer?
          • monster777
            • Jul 2011
            • 41
            Yuup. Everything is to specs . The servo sounds logical. I had one go bad before but once it turned all the way right it stayed there.my problem is only for a second or two.
              Any chance your 5th coil spring is binding? Either the spring coming off the bottom cup or catching on the top cup unevenly and suddenly snapping back into place? I've had this happen (snapped the clip on the bottom cup) and had a similar symptom as the 5th coil was behaving strange and causing unpredictable traction.
              I'd definitely check your bump steer also.
              If you do have a Sweet rack, the solution is not to trash it and buy something new. Sweet racks are fine and if you send it to them they can have it back to you in two days if you think it needs to be checked. Just give them a call. I'm sure Woodward is fine also but Sweet racks are not junk by any means.
              • monster777
                • Jul 2011
                • 41
                Thanks ! I'll double check the 5th coil.i looked at it last night everything looked fine. I have a spare rack and servo . I'll switch it out and see if that helps
                • hucktyson
                  • 1903
                  Matt , bumping wheels results in sweet servos needing rebuilt. You can knock down the wall with a woodward and it's fine. Not to mention the ability to adjust left right bias and servo feel with a 5 minute 20 dollar torsion bar change. The Woodward stuff is smooth and bullet proof the sweet stuff is cheap and fragile. I would rather not have to worry about sending a servo for a rebuild everytime I bump wheels. Maybe junk was the wrong word but it's a citizen watch compared to a Rolex
                  • hpmaster
                    • Aug 2009
                    • 1088
                    Ditto on the Woodward being bulletproof. But remember there are folks that can break an iron ball.
                    • John H
                      • Jun 2011
                      • 24
                      It's possible that it's not even a steering issue at all! It might be a left rear issue.
                      • Brian Gray
                        • Feb 2012
                        • 1102
                        100% agreed been on Tony's stuff for years never had an issue. Unmatched service as well.
                        Shocks by BGR army
                        • grt74
                          • Jul 2009
                          • 1380
                          is the rf spring coil binding???
                          • monster777
                            • Jul 2011
                            • 41
                            I changed the servo and it seemed to cure the problem. Thanks guys.
                            • hucktyson
                              • 1903
                              If you replaced it with another sweet you better send the old one in for repairs because the next minor contact will have you back to square one. On a sweet servo there's a small bearing on 1 end and the valving holds the other end , hence any contact is absorbed by the valving , on a Woodward there's a giant bearing on both ends so contact has no effect on the valving.
