whats the correct answer?????
  • rastus
    • Nov 2007
    • 255
    I have a set of intercomp electric scales . thay are working good . Getting same weight on each scale when checked , but here is the problem :::::: My scales are on real nice pads that hold them about a foot and a half off ground , with a roll off on front to roll car forward zero out and roll back to re scale .when rolling back sometimes the numbers change and car has to be rolled ahead a couplr times in order to get the same weight . it seems as tho they bind up and the moving around the spring loose and numbers start matching again.. any ideas ??????
  • mab475
    • Sep 2010
    • 165
    Do you have the LR axle pulled when you are scaling? It can cause binding that can give false readings due to side load.
    • LM14
      • 490
      I always shake a car by holding onto the roll cage and let it settle on the scales. If you shake t the same way every time you will repeat weights better.
      SPark
      • mab475
        • Sep 2010
        • 165
        Also I remove the compression and rebound from the shocks
        • Brian Gray
          • Feb 2012
          • 1102
          Try pushing the car down at front and rear. Don't bounce it just push down and let the springs bring it back up.
          Shocks by BGR army
          • DaveBauerSS6
            • Jun 2010
            • 566
            2X. Corrected my error.
            Gator Engineering
            • powerslide
              • 2696
              Tell me more...
              • mab475
                • Sep 2010
                • 165
                To much compression or rebound can effect the scale numbers by holding the car in a unrelaxed position after you shake or pull down or however you choose to settle the suspension.
                • powerslide
                  • 2696
                  So exactly what are you doing to remove it?
                  • mab475
                    • Sep 2010
                    • 165
                    On a double adjustable shock I take both to their minimum so it's effect is minimal
                    • powerslide
                      • 2696
                      I had a blond moment I thought we were in the mod section, makes sense
                      • rastus
                        • Nov 2007
                        • 255
                        thank you all !!!!!!!!!!
                        • mab475
                          • Sep 2010
                          • 165
                          Did it help?
                          • FlatTire
                            • 560
                            Also the front end can get held up and give you incorrect readings. Take some door skirt plastic and put two pieces under each tire.
                            • 7uptruckracer
                              Single Load Cells Vs Double makes a difference too. Single Load cells are super sensitive to exact car placement each time I throw them off a cliff
