90s vs 92s ft tires
  • GRTLRBITE
    • 787
    90s vs 92s ft tires
    how would car handle with 90s vs 92s on ft tires? wrs-55 tires?
  • FlatTire
    • 560
    With shorter tires on the front, you will be a little more free on entry and have a little less forward bite getting off. You are basically changing the location of your longitudinal roll axis connecting the front end to the rear end.
    • TheJet-09
      • Jul 2013
      • 1616
      You should be able to expect less deflection with a smaller tire, therefore better steering response. I don't see too many guys running 92's on the front anymore.
      • TALON75
        • 887
        It'll steer better, don't worry too much about the longitudinal roll axis. Try it without changing your setup before you go making changes to your setup.
        www.RACE91.com
        • RW57
          • 662
          We do it for cost reason 3 92s 1 90 on lr so we can put lf on rf or rr when needed and put wore tire on lf
          • jmayabb
            • 178
            I do it for cost reasons too. It also helps with ground clearance on the frame.
            Joe's Race Parts
            From Mild to Wild...
            and Everything in Between
            http://www.191speedway.com
            http://www.joesraceparts.com
            • FlatTire
              • 560
              I like buying 3 92's so it gives me some options when it comes to stagger.
              • RW57
                • 662
                Actually for us rf is biggest of the 3
