If your car is pretty good early in the evening for heat races what kind of changes or areasdo you guys adjust for a track that has taken a good bit of rubber before your feature?
Rubbered up track adjustments
You have to loosen the car up when it goes rubber down. I haven't seen rubber down very often, but I have seen super dry slick confused with rubber down, and the setup will be completely different. As soon as the track starts to take rubber the car will become very tight.
I've only been on a locked down track once or twice (Danville, Il). I've also raced a dirt car on asphalt twice, but that was with asphalt tires. On both accounts, fun as heck, but not good racing. It resembled an extremely high horsepower go-cart. Everything seems to get over sensitive. A little tight is extremely tight. I think you will find it to be the ultimate test of your front-ends capabilities. There's definitely more speed to be found in the front than in the rear.
harder tires, free the car up a little. do not snug for the center of the corner. slower is faster if you're in the rubber. lap times will speed up
