Adding weight?
  • ckyracer00
    • 284
    Adding weight?
    I need to add about 65 #'s to my car to make min weight and was wondering where the best place to add weight to the car would be without throwing my scale numbers to bad?
  • grt74
    • Jul 2009
    • 1380
    center of the car,if the % is good
    • ckyracer00
      • 284
      High or low
      • grt74
        • Jul 2009
        • 1380
        more roll up high,if its rolling enough middle to bottom,most cars have a bar in front of the 5&6 coil
        • LM14
          • 490
          Put the car on the scales and just lay the weights on the decking to see where you can put it without upsetting the car. Probably above/around the tranny in most cars. Once you see the locations that work for you, you can decide on where to actually mount them.
          SPark
          • swartzman
            • 718
            Straight beside the seat on the tunnel
            • centralpa43
              • May 2014
              • 43
              if you only want to add weight for minimum weight I'd keep it in the tunnel above the driveshaft. keep it out of the drivers compartment for safety reasons.
              • jedclampit
                • 613
                Great minds think alike! I'm with him.
                • swartzman
                  • 718
                  Yeah that's what is good about this section: you can get alot of good ideas or be like how in the heck did you come up with that..
                  • AmickRacing
                    • 236
                    If possible, find a place where you can mount it lower, and higher. It's a good experiment for when the track conditions change and you need to make it move around a little more.
                    Home Page
                    http://www.AmickRacing.com
