We want to move the Lift bar toward the drivers side where the 5th coil shock mounts. We initially made a bracket the clamps onto the original lift bar frame tubing and come out the 3 inches we were moving it. So, the 5th coil isnt mounted directly inline on the frame any more. My question, has anyone done this, because im having some concerns that because im not inline with the lift bar frame tubing anymore it might not be working the way i think it is. Do i need to do something different than just my 3 inch extension off that tubing? The rear-end mounts are staying the same, i just wanted to try and move the location of there the 5th coil mounts to the frame. Any ideas, or experience
How to move the LIFT Bar properly
I'm sure it's my sleep deprivation, but I can't exactly picture what your talking about.?! You moved the fifth coil from right to left in the chassis 3"? I'm surprised that you had that much room to work with based on clearing the driveshaft. Is the fifth coil still relatively straight up and down in the chassis? If you could post a picture it might help.
DEK, that is what I was thinking after making the adjustment. I also could be loosing leverage because it's not inline with the original frame mount any more. I was trying to change the leverage being applied to the lift bar. It's been raced this way with no noticeable differences. And after rethinking I don't think I accomplished what I was trying to do correctly.
The lift bar is absorbing torque at the 5th coil spring. The lift bar doesn't know the angle of the spring of what it's attached to. It only feels a resistance to torque which is determined by the spring rate and it's mounting location relative to the source of the torque.
If there's enough torque and enough spring rate to create actual lift, then the location of the upper mount really starts to matter.
There has been debate forever about how to brace the lift bar yet there is still no consensus on the best way to do it. If there was a proven BEST way to do it, that's the way everybody would do it...but they don't so...
if you want to see a dramatic difference move the lift bar to the left side of the rear end.
You will have to make it cross over driveshaft, but it will plant the lr hard.Last edited by JustAddDirt; 06-11-2014, 11:03 AM.I think there should be lifeguards in the genepool.
any, I edited post, but you were to quick on reply.
I don't have any photos of it.
a friend of mine done it on a mod,
I drove the car with lift bar in standard location, and I told him it was driving too hard off the RR. he builds a lot of parts, so I told him to try and mount the lift bar on the left side bell, and he did it.
He make it out of round tube, and it came off the rear end, and it went over the top of driveshaft at an angle, and to the standard 5th/6th coil mounting locations.
He had to build it out of pretty thick material.
Car had a considerable noticeable difference in forward traction.Last edited by JustAddDirt; 06-11-2014, 03:07 PM.I think there should be lifeguards in the genepool.
I believe GRT used to make a liftbar that utilized the same spring location but mounted on the left side of the rearend. It's been my understanding that the effect of the 5th coil on the rearend (left to right) was actually determined by running a straight line through the 5th coil location, perpindicular to the rear end...not where the lift bar mounted to the rear end. An example given was Moyer apparently running his 5th coil to the right on occasion, which felt like having RR in the car under acceleration. The pullbar example mentioned earlier most likely also involved relocating the "chassis" mount location as well (at least I hope), which would prove this.
