what would the efect be
  • izzy9
    • Jan 2008
    • 39
    2011 blue front rocket if you had a 18,75 in. left top rod in place of 16.75 (short bracket) rod by mistake what would the effect be ?? thanks izzy9
  • TALON75
    • 887
    Less drive, due to less indexing into the spring. Might also be tight as it may not roll steer as much.
    www.RACE91.com
    • jedclampit
      • 613
      [QUOTE=izzy9;1816412]2011 blue front rocket if you had a 18,75 in. left top rod in place of 16.75 (short bracket) rod by mistake what would the effect be ?? thanks izzy9
      Sounds like it happened to you, what did you notice?
      ......... Bet it took QUITE a few turns in the lr to get the bite # up ...if you scaled it that way!
