Power steering fluid?
  • Rocket_racing
    • Oct 2009
    • 44
    What fluid are you guys using? We have a Sweet rack, Sweet pump. Is it a must to use the $12.00/quart racing stuff?
  • Bob Nunya
    • Nov 2010
    • 59
    Use the Sweet power steering fluid.....you spent 700-800 dollars on a rack and your pump probably cost around 200 so what is a couple quarts of good power steering fluid. I just don't understand some peoples logic
    • joedoozer
      • 745
      Anything wrong with this stuff?
      Crew Chief "Tip of the day":
      • hpmaster
        • Aug 2009
        • 1088
        Not tryin to be a smart yzz but $12.00 isnt that much when you take into account the countless other costs. Just change it a couple times a year and call it insurance.
        • zeke23z
          • 271
          Originally posted by joedoozer View Post
          been using Lucas for 2 years with no problems with Appleton rack and Sweet pump
          www.nanooklodge.com
          • Weight Jack
            • Apr 2008
            • 20
            I would bet that Randy Sweet doesn't own a refinery and I know that all his pumps and servos are make from Delphi parts, so any fluid that meets GM specs should be good.
            • 700horsepower
              • 191
              Sweets fluid is custom blended specifically for racing by a very well known high performance oil company. The pump RPM and pressure are well beyond what any OEM would use and a custom blended oil does help.
              • Weight Jack
                • Apr 2008
                • 20
                So, the place that re-packages hydraulic pumps and controls has a "special" blend of oil made just for them...OK.
                • CHUMBA
                  • 133
                  Check out ED HOWES web site he says he hasnt found anything better than GM brand of power steering fluid, and that a lot different brands are just GM repackaged!
