Question is for the shock gurus !! If you build a canister afco shock with out any bleed in the main piston stack will it make the car act stiff!! If you build 2 shocks with different stacks & they show same numbers on the dyno will they react the same on the track or can they react different ?? Thanks for any info you can reply or pm me !!
Shock guys
if you dyno them and have the same #s,they should act the same,keep in mind if there the same at 3" and not the same at 6" its not the same shock(thats just a quick example)there are a ton of variables in building a shockOriginally posted by dirtdiggerracing View PostQuestion is for the shock gurus !! If you build a canister afco shock with out any bleed in the main piston stack will it make the car act stiff!! If you build 2 shocks with different stacks & they show same numbers on the dyno will they react the same on the track or can they react different ?? Thanks for any info you can reply or pm me !!
