434 timing..
  • jsw444
    • Apr 2008
    • 68
    434 timing..
    whats the best place to start......i always ran the 406 at 34 degrees just wondering if big cubes need different timing....
  • gaz05
    • Oct 2008
    • 10
    What cylinders heads? comp?
      • 14303
      It is totally head dependent.
      • jsw444
        • Apr 2008
        • 68
        dont have alot of info on the motor.....should have that this week.....i know it has 18 degree heads and is 14 to 1 compression.......we ran it tonite at 34 degrees .....run a little warm.......got a little work to do...i will post the motor info as soon as i get it...thanks guys.....
          • 14303
          Don't know which heads you have, but I doubt you want to go over 30 degrees on gas.
          • jsw444
            • Apr 2008
            • 68
            not sure either ...waiting for info from builder......i know performance engineering up here in michigan did them.....as soon i know i will post......30 degrees ....wow that seems retarded ...lol the motor builder has 38 marked on the balancer.....
            • perfconn
              • 3573
              18* needs 32*
              • jsw444
                • Apr 2008
                • 68
                just got done chatting with a guy that is real good with motors...he said 32 as well...........kinda leaning towards that........thanks everybody....learn something everyday .......
                • hpmaster
                  • Aug 2009
                  • 1088
                  My 18 degree Brodix 421 has currently 33 degrees of timing and we ran it at 36 degrees for 3 years and one freshing with no problems. We retarded the cam timing 3 degrees and dropped the ignition timing 3 degrees on the dyno last winter to improve torque and hp curves. I am too broke and cannot risk a good motor guessing on mixture, lash and timing. Dyno time is where all that needs to be figured out not on 4m. jmho.
                  • jsw444
                    • Apr 2008
                    • 68
                    so you are saying that you gained hp's and torque with less timing?????
                    • hpmaster
                      • Aug 2009
                      • 1088
                      You can change the torque and horsepower curves with cam timing.Not really gaining it but making what you have in torque and HP more useable by having at a different point in the rpm range. Retarding cam timing can delay and smooth out the torque curve somewhat at lower RPMS and can make an engine more drivable. A longer stroke engine inherently produces more torque and if the torque curve is too peaky and or too early you can end up with a motor that just blows the tires off. The best way to look at it is like leveling a hill in your yard without adding dirt but move the hill to a different spot or change the slope. Dyno time, if your engine is prepared with an adjustable timing set with a way to easily access it can be a help in changing the curves and helping drivability. Trying different header designs, pipes and mufflers/antireversion chambers can also help as can using lash adjustments and jet changes. BUT a bad cam will never be a good cam no mater where you time it at. Dyno time is about $500.00 but if you are prepared you can learn alot.
                      • FlatTire
                        • 560
                        HPmaster provided some good advice. We've never left the dyno with less power than we originially showed up with. ;-)
                        • jsw444
                          • Apr 2008
                          • 68
                          32 degrees was the ticket...motor ran much better and was running around 200 degrees on the track.....thanks again guys....this site is overwhelmed with good info......thank you.......
