Have there been any changes on front end settings? Car is 2010 S-7 Front end
Is Mastersbilt still recommending same spacers between tie rod and rack, lower control and frame and tie rod and rt spindle etc?
Just curious I have the old MB set up sheet that used to be on the website and just want to make sure still using same spacer sizes.
Also what would you recommend starting the bar locations in the rear.
Either hole locations or degrees
Will be 604 crate having to weight 2400.00
Track is tacky in beginning, slightly in heat and pretty dry in main. Does not take rubber.
