Tire Compound ?
  • huckleberry_hound
    • 206
    Tire Compound ?
    What American Racer Compound is equivilent to Hoosier 1200,1300 1400 ect. ?
  • JTSjet
    • Mar 2010
    • 272
    The short answer in a practical application? 1400 = SD-48 ....sorta kinda... but that's only saying that in a condition that an SD-48 is the perfect choice, the guy that only has hoosiers will likely choose a 1400, vice versa. It gets more complicated the harder or softer you go from that.
    • joedoozer
      • 745
      I assume these are new tire comparisons. How much different do the Hoosier's and the AR's age? If a 1400 is roughly a SD-48, will they punch the same number after 100 laps? Or punch the same number after sanding them, soaking them in some WD-40?
      I have been searching the internet for a table that someone made comparing the compounds of several different tire brands. If I find anything I will post it.
      Crew Chief "Tip of the day":
      • joedoozer
        • 745
        I found this link. Closest I have come so far to a "table" comparing tires.
        http://www.dirtracingforum.com/showt...American-Racer
        • huckleberry_hound
          • 206
          Thanks for the help Joe...
          • Racer63
            • 285
            This is from the Hoosier site. You need to go back to articles from 2006. It's in a tech bulletin dated 01/06/06 Lots easier to read from there site compared to what happened when I copied and pasted it.
            Compound Replacement Chart
            Competitor Comparison
            Old New Hoosier Competitors
            D03
            1100 1100 SD 23
            D06/RD12
            1200 1200 SD 33
            D11/D15
            1300 1300 SD44
            D21
            1350 1350 G45
            D35
            1400 1400 SD 48
            D45/★D55★
            1500 1500 MD56 / G50
            D55
            1600 1600
            CB D70
            1700 1700 HD70
            D28
            2400 2400
            D46
            2500 2500
            SCL D70
            2700 2700
            • r2rocket
              • Jan 2009
              • 94
              What is the difference between an AR Spec-12 versus AR SD-23? I know the 23 is an open comp tire. Thanks to anyone with help?
              • gadirtracer
                • 1039
                I know the AR open tires are a lot wider than the SPEC's.
                Gill T. Azell
