Birdcage rotation
  • dirtdiggerracing
    • Jan 2008
    • 153
    Birdcage rotation
    Can someone tell me why on a mastersbilt smack when the car is weighed out say with 125-150 # of bite & bars in standard holes & around 12 3/4-13" of drop why there is a
    1 1/2" of gap between the nut & LR spring?? I got 2 other cars with 3" of split in the bars & they are preloaded a little!! Seems to me that the smack with only2" of split should stay loaded longer !! Thanks for any info on this !!btw that is with a. 200 spring on all cars !!
  • save the racers
    • May 2013
    • 271
    I misunderstood the question intially i digress
    • SLM98
      • 407
      Check the bar angles with a protractor. Mount might be welded on different
      • Garrettshurling
        • Aug 2010
        • 72
        Are the birdcages the same on both cars?
        Are the 4-bars attached in the same place?
        Owner/Blogger/Crash Test Dummy
        www.nextlevellatemodel.com
          Spring location, relative to axle, both downward and forward/back come into play. As does the angle of the coilover relative to the ground.
          • HuckleberryB4
            • 220
            J bar lengths and location the same?
            • JTSjet
              • Mar 2010
              • 272
              compare the location of your lower shock mount on the birdcage relative to the center of the axle on all of those cars. i'm guessing you'll find the smack car with the shortest measurement.
              • dirtdiggerracing
                • Jan 2008
                • 153
                Bars are same angles with angle gauge on all cars !! Bars are same from center of tubes to mounting points on the bg (4.5") !! Shock mounts on bg are the same drop from center of the tubes !! Angles of shocks are the same at around 18* of angle !! This has bout lost me !! Lol thanks guys for the info !!
