smackdown jbar length
  • jack06
    • Jul 2014
    • 45
    Any opinions on jbar length 21.5 or 18 3/8ths?
    Most folks run the long one. I like the short one.
    • TheJet-09
      • Jul 2013
      • 1616
      I've only tried the short bar once. Noticed my RR tire rubbed the frame some (on an '08). I may have not had it set properly. When using the short bar, how much lower are you mounting it on the frame side (assuming you are at least some)?
      • jack06
        • Jul 2014
        • 45
        1in lower about 7 3/4 in.
        • Garrettshurling
          • Aug 2010
          • 72
          What kind of track are you running on?
          Stop and go with tight corners?
          Momentum track with long sweeping corners?
          Owner/Blogger/Crash Test Dummy
          www.nextlevellatemodel.com
          • jack06
            • Jul 2014
            • 45
            Originally posted by Garrettshurling View Post
            What kind of track are you running on? Stop and go with tight corners?Momentum track with long sweeping corners?
            Tight corners dry slick
            • Garrettshurling
              • Aug 2010
              • 72
              I'd go with the shorter of the two. the short bar will hike the car faster and tighten the car overall.
              • jack06
                • Jul 2014
                • 45
                Should the side to side say the same when running the 18 3/8 jbar? I mounted on the inside of the frame rail.
                  You should maintain side to side.
                  • hpmaster
                    • Aug 2009
                    • 1088
                    Not trying to disagree but the length of the J bar used is as much about driving style as it is anything else.
                    • Garrettshurling
                      • Aug 2010
                      • 72
                      hpmaster, Do you think a smoother driver would be able to run the short bar more often that a driver who treats the gas like an on/off switch?
                      • hpmaster
                        • Aug 2009
                        • 1088
                        It's a combination of factors but a smoother driver often can run a shorter bar better than a guy who is on and off the gas like a on off switch. Some guys you think are on and off the gas can have bigger engines that have torque curves that hit like a sledge hammer. You have to look at the entire car, driver, engine, frt end, rack speed and car set up. If it was just a j bar, set up and shocks we would all be 3 angles and a shock package away from a feature win.
                          A lot of people are only that far off.
                          • grt74
                            • Jul 2009
                            • 1380
                            a can agree with that,thats some of the best tech info on here
