Looking for some experience when to index bird cages and when to lower or raise the height on the bird cage?
When to Index bird cages
What about RR closer or further away to the centerline of the axke for the top link? What are the results in doing this?
Any time you move a top link towards the axle, you give that tire more load and you increase steer.Modern Day Spec Wedge Racing
Well reason I ask is because I want to keep the same load on the spring that particular corner if changing bar angles statically. Now dynamically I don't know the affects exactly. In the other holes above if making a bar adjustment I have to lengthen or shorten them. What are your thoughts?Originally posted by MasterSbilt_Racer View PostAny time you move a top link towards the axle, you give that tire more load and you increase steer.
The arc for the chassis holes should be correct for the standard location on the cage. If not, your ride height is incorrect, the bar length is off, or the brackets were installed incorrectly.Originally posted by DirtRacer9x View PostWell reason I ask is because I want to keep the same load on the spring that particular corner if changing bar angles statically. Now dynamically I don't know the affects exactly. In the other holes above if making a bar adjustment I have to lengthen or shorten them. What are your thoughts?
It is typical for the lr holes to be off a bit because most jigs were not set up to compensate for tire stagger.Modern Day Spec Wedge Racing
Well I have taken all of that into effect. But what is correct and what isn't? Since so much has been changing on these cars every year just would rather know the effect. My holes line up when cage is in bottom hole on rear end side. Thanks.
The explanations I gave you were for dynamic changes from moving down from standard.Modern Day Spec Wedge Racing
Any thoughts on moving the link forward or backward on the bird cage. So it's tipped forward or backward instead of straight up?
