Barrel Springs
  • Race03
    • Jul 2010
    • 6
    Barrel Springs
    Is it worth the cost to switch to barrel springs over the standard coil overs for a limited late model. Have been told to switch to barrel springs because they hold their rate better at any compression but don't see many running them except a few of the well established late model teams. Just want to know if it worth it to spend double the cost of the standard coil over.
  • hpmaster
    • Aug 2009
    • 1088
    Where coil bind is an issue I think they are worth it.
    • Sprint76
      • Aug 2008
      • 76
      I wouldn't worry about them anywhere other than RF. If you're coilbinding, it is absolutely worth it. I haven't seen enough of a rate variance on Eibachs and Hypercoils to justify the investment unless they are coilbinding. I have seen some weird behavior with Integra springs, but it wasn't necessarily just near travel limit.
      • Sprint76
        • Aug 2008
        • 76
        I should also add that you don't necessarily need a barrel spring either. Many of the new Eibach and Hypercoil standard springs are built with less coils, and have had enough travel for me to use without issue.
        • HuckleberryB4
          • 220
          What Sprint76 said. Any new Eibach or Hypercoil will have more coil spacing due to less coils.
          Although a barrel spring could have it's place outside of the RF.
