Bert rear mt starter
  • wallbangerII
    • 55
    What parts house starter can i buy and put my nose on it?
    Is it doable?
    Any tricks?
    Thanks for any help
  • save the racers
    • May 2013
    • 271
    87 toyota pickup
    • JustAddDirt
      • 1893
      87 Toyota
      22r
      manual trans.
      get the big KV motor.
      • TALON75
        • 887
        The ones Bert and brinn are using now are from a 93 Toyota corrolla 1.8L. The ones from Mason were the bigger starters from the 22r motors. At least this is what my research has uncovered, and be careful, not all the starters from the parts house are the same, they have sutle differences that will still work for their intended application, but are not a direct replacement for the bert(mainly the bendix is different and won't fit the Bert nose cone. I have done a handful of my own because I think the new starters from Bert and brinn are all just remans anyway, might as well save some money and get one your self. I prefer carquest brand stuff, but found a delco number that says it is new not reman on rock auto, n- 3371091. Hope this helps
        www.RACE91.com
        • TALON75
          • 887
          Very doable! 4 bolts, watch for the bearings to slide out when you pull it apart. You need to pull the cover off the other end and silicone the wires to the side of the housing for vibration purposes.
          www.RACE91.com
