I have a couple questions if I may get help. I have an 05 Rocket black front that has always run a Chevy motor. Super then Crate. The car has always been fast and handled well. I'm now adding extra weight to the front as the Ford (I have been told) is heavier. I have not scaled the car yet, but does anyone have an idea how much the ford adds? And how will this affect the driving? Do I need to change front springs for the added weight or simply adjust ride height but lose suspension travel? I'm running Genesis G3 shocks all 4 corners but will I have to start all over with my settings? I appreciate all insight I can get. Thank you
Switched from sbc to sbf in Rocket black
Good point. It had a 604 in it and now has a steel head 351w.
You have a heavier engine with a bit higher cg. You may need to lower it a bit. One correction to your comment. If ride height is the same, you will not lose available suspension travel.Modern Day Spec Wedge Racing
Lol you're right about switching. I guess I just couldn't stand supporting GM (Government Motors and Obama) anymore lol
